20pin to 24pin adapter?????
Gaffney982
Easy enough, I have a PCP&C 510 SLI. The Vapo XE Chillcontrol power adapter is a 20 pin on both sides. What's the easiest remedy for this? Should I just go straight from the PSU 24pin to the motherboard connector? Or should I mod the Chillcontrol adapter and put a 24pin male&female on it? Thoughts, suggestions?
You can get em I believe from e-tailors or flee-bay - you just have to snoop around I am afraid.
Most new PSU's gome with the adaptor complete.
Mav
Okay, how about this. How do I hook up my 400watt Enermax psu to the vapochill externally and then keep my PCP&C hooked up straight to the motherboard? Basically use the enermax as an external psu.
I'm a bit rusty on this, but bear with me if i get it wrong.
Hook the Enermax up to the Vapochill and the CC, install a switch (for setup you can just use a paperclip or something) to turn it on it's own, and then install the other PSU so that it is just like a normal air setup, and then i think the Vapochill and the CC should work, and you can turn on the system once the Vapochill is down to temp.
G
Have you tried putting something else like a HDD on that PSU to have some draw on the other lines (some PSUs dont like power draw from only one line)
Does the CC give an error code?
G
I just modded one of these 24pin plugs so that my IMon, and dual PSU would work together - I just took out the relevent pins, and added the additional wires, then pushed them back in place - it works a treat :)
Yay, my new CC will be in tomorrow. I got a whole kit for molex and atx pin removal. I'll just new/neat wires from my psu straight to the mobo!! :-D
