For those of you that do not know the difference between the boards:
The UD7 has 4 x PCI Express x16 slots with 2 slots running at x16 and the other 2 running at x8,
The UD4 has 2 x PCI Express x16 slots with one running at x16 and when you use both the slots they both run at x8.
This is a simple question, for running 2-way SLI: How much of a performance increase will you get when you run the cards at x16 versus x8?
I know that there will be a difference, but how much will it be? The thing is, money is not a problem, this is more of a theoretical question than a buying decision one.
Thank you for any replies
