Hi there chaps...
Has anyone done a 2 PSU setup.
I have followed a guide which is quite simple..
get a 2 ATX extention cables. On one strip all the pins out and connect 7 to 8. The connect 14 on one to 14 on the good atx cable and the same with 15
Then plug in and go.. Easy enough.. and it works, sort of
I have the following hardware.. 4 hdds 2xSATA and 2xIDE and 2xCDROMS 1x 6800ULTRA 2xpumps and some fans....
this is all running on a Antec 480w PSU at the mo
so the setup is now this with the 2 psu's
on the Antec True Power I am running the 6800, MB and the 2 pumps and on the 550w Qtec I have the 4 hdds, 2 CDRoms and the fans....
It all powers on OK and boots... but it keeps hanging and I have also had 1 blue screen..
Any ideas or is there a setup that you can go out and buy??
Help....
Help....
