Dawelio
Active member
Hey guys,
I could use some advice, since I'm not really that into laptops etc...
I wanna get a 2-1 laptop, for more portability.
Now, I won't be gaming on it, maybe some light web games on killsometime.com as an example. But mostly just browsing the web, watching youtube, stream movies etc.
Write some documents also.
Which one of these 2 would you then take for the smoothest experience, ie no lag due to poor performance. Since I want it to be quite capable of these tasks.
Since I have an Denver TAC-70072 and it's literally crap, hence me wanting to replace it with an 2-1 or 2 in 1.
https://www.netonnet.se/art/dator/s...ormer-book-flip-tp200sa-fv0108ts/222254.8950/
http://www.mediamarkt.se/sv/product/_lamina-lamina-10-t-1010b-1280690.html
I do really like the look of both, but not sure which one would fit me best.
I'm also searching for one with rather good battery life, that could last a day, up to 12 hours, if not a little more.
Do you guys perhaps have some recommendations for one?...
Budget would be around £200-300. But could be streched to £400-500. But want to be within $200-300 range, since I don't believe it takes that much specs for the light workload I've mentioned above.
Thanks,
Chrazey
Thanks,
Chrazey
