Okay, well, for arguments sake:
MSI R9 290X Gaming - $800 - 1040MHz - 4GB
MSI GTX 780 Ti Gaming - $760 - 1020MHz/1085MHz - 3GB
MSI R9 290 Gaming - $600 - 1007MHz - 4GB
MSI GTX 780 Gaming - $550 - 954MHz/1006MHz - 3GB
MSI R9 280X Gaming - $500 - 1000MHz/1050MHz - 3GB
MSI GTX 770 Gaming - $420 - 1137MHz/1189MHz - 4GB
Those are the prices on all the high end cards on Newegg Canada. I will not buy a card with a stock cooler, just much too loud. I honestly prefer nVidia to AMD for their drivers, and I prefer a strong single GPU to an SLI setup. A lot of you think I could do better for the money though, so have at it. What do you think would get me the best FPS for under $1000? Please back-up your answer with facts, benches are appreciated. Honestly, if I were to go SLI I'm thinking GTX 770 4GB would be my best bet.
Also, the more I look at the Corsair C70 Vengeance, the more I like it. I think that's going to be my case.
Wow those prices are horrendous...
I would go for 2 R9 280X. If you really want to get maximum everything at 60 FPS at 2560 x 1440, a single card, even an incredibly overclocked 780Ti just isn't enough. The extra VRAM in the 4GB 770 is not very useful at all due to its memory bus + you won't be playing multi monitor even at 1440p you don't really need it, and the R9 280X performs better at higher resolutions due to its larger memory bus.
However, after seeing those prices I am not so sure... I have never seen an AMD card more expensive than its nvidia counter part, even here with inflated prices, AMD is still cheaper. Maybe your best bet is indeed 770 4GB, I mean... they are so much cheaper and will perform very similarly.
http://www.techoftomorrow.com/2013/pc/amd-r9-280x-crossfire-results-benchmarks/
As you can see R9 280X in crossfire makes mincemeat out of literally everything.
http://www.guru3d.com/articles_pages/geforce_gtx_770_sli_review,17.html
770 SLI is close but very slightly slower, more so at 2560 x 1440 due to its memory bus.
From most benchmarks I can find at 2560 x 1440 770 SLI is usually around 3-5 FPS slower than 280X. Which isn't much at all, so might be worth going for since its much cheaper by your prices.
EDIT: Just looked up prices, cheapest decent 280X I can see on Newegg CA is $460, whereas you can get 2GB 770's for only $380 and 4GB 770 for $420! That is insane... you guys have rough prices.
Then again, we ALWAYS have rougher prices than you so I guess its not too bad
I would go SLI 770. Personally, go for 2GB, however if you plan for not upgrading for a while might be worth going 4GB, some games at 2560 x 1440 push 2GB atm.
