12v car adapters
AMDFTW
alryt
were can u get some 12v to normal plug socket adpater or transformers from
scan sell some but they have 1 plug i was after one with 4 on if the exist
you mean 12v to 240v?
You'll never get one with four if that's what you mean dude.
Also, those things are seriously limited to the wattages of what you want to plug in. Game consoles are fine, 'cos most are really 12v inside and have a transformer (so low wattage).
well i said to my mate 'no you can just get the one' apparently halfords have some with 4 on
and yes 240v you so you can plug laptops and phone chargers
Yeah with those it'll be fine tbh. Just don't go putting in 50 inch plasmas
Aye and pull over 5Amps you will have problems.
Its an INvertor you will need, depends on wattage to anything upto 600watts and you can easily be spending 300 notes.
Nice and cheap ones with overvolt protection i wouldnt trust with a barge pole obviously cost a lot less.
