1 Rad
Nick R
Is 1 radiator with a 150 CFM fan enough to cool a 3GHz Q9650 OCed to 4GHz, and if it is, can the chipset run on the same loop. I intend to run dual loop with the graphics card on their own loop.
Thermochill PA120 :)
Im guessing the fan you had in mind was a delta or something? It would be incredibly loud.
I was just going for the most optimized cooling, nothing is set in stone but I was looking at a Scythe Ultra.
name='NobodyNowhereNothing' said:
If you dont mind spending a little more, i would go with :
http://www.tekheads.co.uk/s/product?product=608206
I have 7 of this in my setup!!! ( 3 for the rad, 4 for antec 900 )
They are silent (14db ) at the same time pushing 72cfm of air!
Also, i would second Thermochill PA120!
Gd luck
that is a lot of money for a single fan,the standard fans in the 900 push 60 cfm anyway
Gd luck
Sorry but I REALLY don't beleive those fan specs.
Send one over to SilentPC or somewhere similar and get them to do some proper testing on them!
EDIT: quick search on the net:
http://www.silentpcreview.com/article739-page3.html
Quote from the article:
1- A SilenX spokesman was caught shilling his product by carrying on a conversation with himself on SPCR's forums, reregistering himself several times after his fraudulent activities were exposed by SPCR staff.
2- SilenX' specifications are notoriously exaggerated, especially where noise is concerned.
Thanks to widespread distribution and aggressive marketing (see point 2.), SilenX fans have a reputation for being quiet — but not on SPCR
3- For a very long time, in part because of point 1., SPCR had never "officially" reviewed a SilenX product.
Seems like they lie about their specs im afraid, bet that was the best £150 you've spent in your life...
...that is if you actually paid for the 7 you are using?
:p
:p
Ohum well google ads paid for them :D but still, i could have spent that on something much better ( seems so stupid now!!! ) .. to be honest i am very happy with the fans however i do wish i would have gone for normal £5 fans and just used my fan controller to turn them way down when i want the PC quiet ...
I am, building and sellings PCs off every day anyway so it wont be much problem for me to change / sell this overtime and make some of the money back!
How are this fans:
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=649586
I couldnt find any reviewd for them,
Edit: Thanks for the time you spent to search for this info!
-- NNN
