Go Back   OC3D Forums > [OC3D] Processors & Platforms > Memory
Thread Tools Display Modes
  #1
Old 22-10-18, 08:02 PM
Bob_Kelso Bob_Kelso is offline
Newbie
New pc won't boot after trying to fix memory problems.
So I had my new pc working for a day, installed updates run a game did a few tests etc all seemed good. But then I saw windows 10 only using 8gb of 16gb. So I go ahead and turn the pc off and turn power supply off on the back, wait a minute test the first ram stick boots fine test the other it get's into bios then the 30 seconds later the pc shuts off and won't start up.
I tried rebooting again nothing, cleared cmos nothing. Now I'm unplugging everything and taking battery out and putting it back in.
Pc speccs here https://uk.pcpartpicker.com/list/MqtMyX
  #2
Old 22-10-18, 08:11 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
whats being displayed on the debug display?
__________________
ASUS ROG Crosshair VII wifi | Ryzen 5 3600 | Custom Loop | Patriot Viper Steel 4133 @ 3600 2 x 8Gb | Asus Strix RX 470 | Samsung 500gb nvme | Samsung 1Tb nvme | Samsung Evo 120gb ssd | Seagate Barracuda 1tb storage | Toshiba 1Tb HDD | EVGA 500w | Phanteks Entho Pro Tempered Glass | Windows 10 and Linux Manjaro
  #3
Old 22-10-18, 08:14 PM
Newbie
It won't start up at all so nothing welp.
  #4
Old 22-10-18, 08:18 PM
RobM's Avatar
OC3D Elite
seems like something has gone pop, time to start sniffing things to see if they smell odd are psu or mobo might smell of electric burn.
You could try the psu cable on your kettle to rule out the fuse there
__________________
  #5
Old 22-10-18, 08:24 PM
Newbie
The cable is fine good little trick to test on the kettle, there is no "burning" smell when it shut down there was nothing really unusual about it, it just turned off.
I took out the psu and had a look there was no visible damage/burn marks.
  #6
Old 22-10-18, 08:36 PM
RobM's Avatar
OC3D Elite
are you able to test with another psu or mobo?
__________________
  #7
Old 22-10-18, 08:41 PM
Newbie
Psu yes motherboard no, and it's also late so tearing down the old build is not really an option right now maybe tomorrow idk.
  #8
Old 22-10-18, 08:47 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Incorrect RAM addressing usually = bent pins in the socket. Take the CPU out and have a good look..
Edit. Never mind that, that's an Intel thing. However I would remove the CPU and make sure everything is OK on the pins.
__________________
If you don't like what I post don't read it.
  #9
Old 22-10-18, 10:15 PM
Newbie
Ok so I unplugged everything reset the cmos took out the battery for 10 mins hooked it all back it booted into windows and is now showing 16gb ram available.
So now hopefully all is well ty for the help.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
