Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
Thread Tools Display Modes
  #11
Old 18-12-17, 11:11 AM
Warchild Warchild is offline
OC3D Elite
I honestly dont see why you cant clock at 4.5 (at most) and get the same kind of results.
4.4 is far, FAR more stable. You are limited by the chip capabilities. If you get unlucky then 5.0 is just not in scope at all.
  #12
Old 18-12-17, 11:23 AM
looz's Avatar
looz looz is offline
OC3D Elite
Honestly a chip which is borderline stable at 5.0 should do 4.8 or 4.9 quite easily, so why not aim a little higher when we're at oc3d of all places. :P
__________________
i7 8700k - 16GB - 2060 FE - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
  #13
Old 18-12-17, 12:17 PM
OC3D Elite
Because he wants to stream and there is nothing more embarassing that a blue screen of death when streaming. otherwise I'd say could go balls to the wall even if there is no significant gain at 5.0.
  #14
Old 18-12-17, 12:34 PM
7UpDiet 7UpDiet is offline
Newbie
thanks for the feedback guys..
tbh i want the max out of my rig. i'm gonna try to increase my voltage up to 1.35 at max
if i dont get result , i will drop down to either 4.9 or 4.8 i havent decided yet
but i'm not sure what voltage to start with when testing 4.9 or 4.8
  #15
Old 18-12-17, 12:54 PM
looz's Avatar
OC3D Elite
Don't do 1.35 if lower voltage already causes thermal issues... Sometimes you have to settle with lower clocks.
__________________
  #16
Old 18-12-17, 01:09 PM
OC3D Elite
1.35V may be adequate but it will degrade the life of your CPU. Not to mention the heat you will produce will rise.
  #17
Old 18-12-17, 01:20 PM
Newbie
Hhmm i will try to go up to 1.3v and do a test you know?
just to see how it goes because i have brand new setup so if there is heating issue with my corsair h100i v2. i would like to know about it.
  #18
Old 18-12-17, 03:15 PM
looz's Avatar
OC3D Elite
Stress test 4.9 at 1.27v, if that doesn't work do 4.8 at 1.27v.
__________________
  #19
Old 18-12-17, 05:10 PM
Newbie
guys, while using prime95
which stress test to go for?
there are three options and i know the difference between them (less ram stress,more cpu...etc)
im asking which one will be good for my stress test?
  #20
Old 18-12-17, 07:04 PM
AMD Enthusiast
If you are OC'ing the CPU then choose the test that stresses the CPU.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
