Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #11
Old 07-09-14, 12:33 PM
TPC's Avatar
TPC TPC is offline
OC3D Elite
Originally Posted by RamboOC View Post
Thanks for the heads up.
I knew that the performance increase was not going to be much, but I underestimated by how much. I think the top of the line GTX 980 would be easily beaten by a reference overclocked air cooled GTX 780TI.
Nvidia better have cut the power usage drastically/ made the card much smaller so that it fits in small htpc or there's not going to be that much point in upgrading from the 780/TI
I only want to see one 6pin,or 8 pin for the "overclocking" cards
  #12
Old 07-09-14, 03:23 PM
Eldast4Thech Eldast4Thech is offline
Newbie
I hope we'll be able to overclock these GPUs as much as actual GTX 770 and 780
  #13
Old 07-09-14, 05:00 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
I want at least 25% faster stock v stock with 8GB memory, Until that time comes I'll stick with the 780 Ti.
__________________
=Origin-Steam-Uplay-XBLive - Dicehunter=
  #14
Old 07-09-14, 06:20 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Very wise, I'm just still bemused as to why nVidia decided to skip 800 Series name though...
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #15
Old 07-09-14, 06:29 PM
TPC's Avatar
TPC TPC is offline
OC3D Elite
800 is mobile series Maxwell
900 Desktop Maxwell
1000 Mobile GPU
1100 Desktop GPU
Me thinks
  #16
Old 07-09-14, 06:34 PM
Silver Sparrow's Avatar
Silver Sparrow Silver Sparrow is offline
Member
What is this card compared to the GTX 770 or the 780 in terms of product stack? If it's a replacement for the 680/770 on the same fab process those are rather impressive results. Nice 4GB vram to boot.
I have to admit I was expecting a bit more, especially with all the rumours, if I were to upgrade [at least beating the 780ti would make me consider it] but if it is to replace the 780 then is this just the r9 285 nvidia style?! If so all rather uninspiring.
__________________
F4TG1RL: i5 3570k wc | MSI Z77 GD65 | R9 290 Xfirewc | 8GB DDR3 1600 | Samsung 830 250GB | Fractal Arc Midi R2 | CM V1000
wc: GPU EK R9-290 FC Acetal & Backplate | CPU EK-Supreme LTX - Nickel CSQ | Fittings Monsoon Black Chrome & Primochill PF LRT Onyx Black | Pump XSPC Nylon Dual Bay Reservoir & Laing D5 Vario | Radiator Alphacool NexXxoS Monsta 240
  #17
Old 07-09-14, 07:08 PM
SeekaX SeekaX is offline
OC3D Elite
900 Desktop Maxwell
1000 Mobile GPU
1100 Desktop GPU
Me thinks
Nope, there is a 900 series for mobile coming as well. I think the reason is that the mobile GPUs were one generation ahead of the desktop GPUs, i.e. there are already 8xx mobile cards.
  #18
Old 07-09-14, 07:41 PM
TPC's Avatar
TPC TPC is offline
OC3D Elite
Ok well then the mystery of the 800 desktop skipment is still unsolved
  #19
Old 07-09-14, 08:41 PM
Zoot's Avatar
Zoot Zoot is offline
OC3D Elite
Why did they skip the 800 series? They skipped the 300 series back ~4 years or so ago, for whatever reason.
Nvidia's branding has gone through many weird transitions, but then again I can't think of a single company that does branding well. They all make an obscene mess at some point.
__________________
Desktop: AMD Ryzen 7 3700X | X570i Aorus | 32GB Corsair DDR4-3200MHz | RX 5700 XT | Aorus PCIe 4.0 1TB M.2 | Fractal Define Nano S
Home Server: AMD Ryzen 3 2200G | Asus Prime B450M-A | 16GB Crucial DDR4-2400MHz | 39TB | Fractal Design Define R5
HTPC: AMD Athlon 5350 | ASRock AM1H-ITX | 4GB Corsair DDR3-1333MHz | MiniBox M350
  #20
Old 08-09-14, 11:24 AM
Dicehunter's Avatar
Resident Newb
980 Ti on it's way -
__________________
Tags
970, 980, gigabyte, gtx, leak
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
