Thread Tools Display Modes
  #1
Old 07-09-13, 03:35 PM
jgibson667 jgibson667 is offline
Newbie
Any advice on improving this gaming build?
Can anyone give me any pointers to maybe increase the value for money on this build or improve it in any way whilst keeping the price fairly similar to what it already is? I'm getting my case from a friend, by the way.
Cheers!
http://www.scan.co.uk/savedbasket/19...4a3c8df1f741e4
  #2
Old 07-09-13, 03:43 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Well ehm... a case could be convenient?
Also, see if you can find 1600MHz RAM with a CAS Latency of 9. 10 is a bit high for 1600MHz RAM tbh. Do you really need 2TB of storage?
Also please answer these questions:
• What will you be using this rig for?
• If gaming, what resolution will you be playing at?
• Will you be overclocking?
• Do you need a full build or will you be reusing some old parts?
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #3
Old 07-09-13, 03:48 PM
WYP's Avatar
WYP WYP is offline
News Guru
please change to a piledriver processor, you will save power and gain performance.
If you can go for the fx 6300, its worth the extra £15. two more cores, less heat output and lower power consumption
__________________
_______________________________
Twitter - @WYP_PC
  #4
Old 07-09-13, 03:57 PM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
the fx4130 doesn't have the best performance, go for the fx6300 as it has a big boost in performance over the 4130 ands would enable you to make full use of the 660. Also, go for an aftermarket cpu cooler, as the stock AMD one is awful. This would be your best bet. If you can't get the cooler straight away, make sure to get one at a later date as the 6300's stock cooler isn't really very effective and is quite noisy.
__________________
Rig: i7 [email protected]|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904| 970 EVO 500GB m.2|512GB evo 840| Crucial MX 500 500GB|ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
  #5
Old 07-09-13, 04:04 PM
Newbie
I said that I'm getting my case separately. The rig is for gaming, on a 1920x1080 monitor. I won't be overclocking, and it's a full from-scratch build, yes.
I expected my processor wouldn't be the best value for money. What aftermarket cooler would you recommend?
And I may not need 2TB of storage, but I'm guilty of filling up my drives pretty quick and I figured I'll eventually need a 2nd TB anyway, so why not. How much difference does a higher latency make?
Sorry I just realized you linked me to a cooler, thanks.
  #6
Old 07-09-13, 04:13 PM
Feronix's Avatar
OC3D Elite
Edit; Ninja'd
First of all, please use the multi-quote button instead of posting twice, thanks
Oh my bad, I missed that part. What case is it exactly? What games will you be playing?
The underlined word in his post is clickable and leads to this:
http://www.scan.co.uk/products/coole...55-1156-1366-a
I can do nothing but agree with this suggestion. Granted it's a bit on the expensive side for a budget build, it's the absolute best cooler for the money.
__________________
~Rick
  #7
Old 07-09-13, 04:14 PM
barnsley's Avatar
born in a.....
No problem.
I think the rest of your build will be fine . Just out of interest, what case are you getting from your friend?
__________________
  #8
Old 07-09-13, 04:57 PM
Newbie
I'll be playing indie games, and shooters such as Battlefield, Counter-Strike, GTA, Crysis and just generally anything else that peaks my interest. The case is a BitFenix Colossus, and it's costing me only £30 I think, so that's good.
  #9
Old 07-09-13, 05:05 PM
barnsley's Avatar
born in a.....
Yeah, considering it is £139.96 new xD. Your setup will play those games fine .
__________________
  #10
Old 07-09-13, 05:12 PM
Newbie
I know haha! Great, the price is a bit higher than I first wanted with the new CPU and the cooler, £499.79. After a bit of research, you guys are right though. I'll buy the items one or two at a time and I'll be able to afford it that way. Cheers for the assistance guys!
Tags
build, gaming
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
