Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section
Thread Tools Display Modes
  #11
Old 03-10-15, 05:47 AM
MajorMajor's Avatar
MajorMajor MajorMajor is offline
Newbie
Can you start the task manager? Maybe try restarting the Explorer process.
__________________
Das Keyboard Pro 4 | Zotac GTX780 | 4x4GB Kingston Hyper X RAM | Core i5 |Gigabyte GA Z97X| Coding Supply
  #12
Old 04-10-15, 10:16 PM
TheHunter's Avatar
TheHunter TheHunter is offline
Newbie
this will restore your start button functionality
open powershell (run as admin) and copy-paste this text
Get-AppXPackage -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
close power shell and try to open start menu..
if it still doesn't work try this, again run powershell as admin and type in this, just copy-paste and press enter
$manifest = (Get-AppxPackage Microsoft.WindowsStore).InstallLocation + '\AppxManifest.xml' ; Add-AppxPackage -DisableDevelopmentMode -Register $manifest
*Close the Powershell window
* Reboot
__________________
Tags
freezing, windows 10
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
