Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #11
Old 21-01-15, 05:55 PM
tinytomlogan's Avatar
The Guvnor
Ram wont auto run at 2400 you have to set it up / use XMP fella.... I say this in every single one of these threads......
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #12
Old 21-01-15, 05:58 PM
AMD Enthusiast
If you get a BSOD on an OC or underclock then it's unstable and volts should be lowered/raise till stabiltity happens.
In the Bios what have you left on auto?
For reference, M&P on this forum has done a guide. While it is Ivy Bridge, just go down to the terminology part and read up on a few of them to see if they aid you in temps.
http://forum.overclock3d.net/showthread.php?t=45604
He knows Tom. He said he left it at 1333 for the time being.
  #13
Old 21-01-15, 05:59 PM
MicroAlex's Avatar
MicroAlex MicroAlex is offline
Newbie
Hey TOM,
I dont want them to run at 2400mhz, I am excluding this option for testing purposes.
I was running them at the specified speeds via XMP before we started troubleshooting on this forum.
__________________
To all of the FANS - http://microalex.deviantart.com/art/...sair-347479555
Tags
aio, bubbles, fractal-design, s24 kelvin, watercooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
