Thread Tools Display Modes
  #11
Old 18-12-12, 07:30 PM
zaft1g337 zaft1g337 is offline
Member
Originally Posted by GameDaneDK View Post
There's nothing wrong with looking at other peoples work for inspiration, and to spark ones imagination.
The point is not that you should not look at other peoples work, the point is, that you should not copy other peoples work, at least that's my take on it.
Exactly what im trying to fish up Come on, who would be pleased knowing that the thing they did, was only an imitation of someone else's work? Copying is illegal, i know this too well as a master degree student. As for me, i do have the patience, but not the time really. if i do an extensive modding i would not be done with it after a year, maybe more.
As i live now, its something like 50% studying 30% working and 20% hobby. And as can be seen; more work = more awesome computer, but at the same time = less time to mod myself which is not that great to be honest. bcuz i feel like by the time im done with building my awesome rig, im already a grandpa lol xP
never mind that. thanks for ur feedback. more ideas are welcome!
oh btw, is the cm 212+ a good cooler for a non-oc'ed 3770k?
  #12
Old 18-12-12, 10:18 PM
JMMP's Avatar
JMMP JMMP is offline
OC3D Crew
You will have no problem with CM 212+!
__________________
  #13
Old 19-12-12, 05:34 AM
Choklitmlk's Avatar
Choklitmlk Choklitmlk is offline
Member
most basic mods dont take as long as you think, you can completely transform a case in just a single day off with nothing more than a few tools and some imagination
__________________
--> Check out my mATX mod watercooling build <--
3770k @ 4.5GHz * Maximus V Gene * 2x GTX670 4GB @ 1.02GHz
Ripjaws Z 4x4gb @ 2133MHz * 2x256gb 840 pro * 750gb Black
AX750 * custom water cooled * modded Define Mini
Intel - Asus - EVGA - G.Skill - Corsair - Samsung - Western Digital - EKWB - XSPC - Fractal Design
  #14
Old 20-12-12, 01:30 PM
Member
yeah, the thing is that im pretty bad with tools :P so ill have to practice a while before starting on the actual work, which i assume will be exciting. But then again, i dont know a lot about tools, so ill have to spend some time learing what they are called, what they are used for and how =) The only thing ive used are chainsaws, and drills. *very proud* not xP
huuh... this will be fun
Tags
build, red, stryker, switch 810, white
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
