Thread Tools Display Modes
  #11
Old 21-06-12, 02:01 PM
chrisjones chrisjones is offline
Newbie
Send a message via MSN to chrisjones
I was contemplating using the 650d, but putting a 360 rad in the top would be a bit too much of a challenge for me I think, whats your guys opinions on this? a black and red theme, instead of white, black and red.
__________________
Fractal Define R6, Asus WS390-Pro, Intel i7 9700k @5.2GHz, Corsair Dominator Platinum 32GB 3200MHz, EVGA RTX 2080 Super, Corsair RM1000i, Noctua NH-U12S, Samsung 970 Evo M.2 1TB SSD
Fractal Node 304, Asus Z87I-Pro, Intel i5 4670K @4.2GHz, Corsair LP 8GB RAM, Gainward GTX960, Corsair RM550, Corsair H75, Sandisk Ultra II 240GB SSD, 1x WD RED 3TB, 4x WD Green 2TB
  #12
Old 22-06-12, 02:02 PM
Newbie
anyone got any input on other cases that would work well with this sort of rig, would have to be able to fit a 360 in the top, with a little modding, but nothing major?
__________________
  #13
Old 24-06-12, 12:05 AM
Newbie
guys would there be much of a price difference between the maximus v formula and the extreme? contemplating the upgrade, then just having the 360 on the cpu, which gives me the option to upgrade to a waterblock for the GTX680 in the future, opinions?
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
