Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
Thread Tools Display Modes
  #181
Old 11-03-19, 07:04 PM
scubasteve scubasteve is offline
Advanced Member
Originally Posted by Damien c View Post
Just got the Dead Rabbit RTA.
It's not bad but I am on the lookout for a different RTA, where it doesn't leak from the bottom like the one I was using but cannot remember the name of it, but think it is a Geekvape one because the seal at the bottom, is so poor that it just leaks.
Still trying to find as well a decent place to get flavour concentrates from that are not harsh on my throat.
you looking for dual coil or single cos theres a few single coils coming out that look really good and as for dual coils have a look at this
or
another dual
  #182
Old 11-03-19, 11:24 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Forgot to update.. Mesh coils last 1-2 weeks at full flavour before turning black and tasting bad. Shame you can't change the "tampon" thing in there.. However I am now buying them at less than £10 for three. So I've hardly had to buy any since buying it. It does depend on what I am vaping. If it's menthol/watermelon it lasts ages. Donuts and tings does tend to make them go faster though.
__________________
"Those really high 20 series prices are just place holders"
  #183
Old 12-03-19, 06:19 AM
Damien c Damien c is offline
OC3D Elite
Yeah dual coil is what I am after.
The one that was constantly leaking is the Geekvape Ammit Dual Coil, where the build deck section comes away from the tank is where it leaks from constantly.
This Dead Rabbit RTA will do for now, and I will see what comes out over the next couple of months, the issue with it is that it's like a RDTA but without the ability to drip it.
The coil section is raised like it is in the RDA version, but because of the way it's built it can cause alot of dry hit's and takes a while to wick after a couple of pulls.
This Dead Rabbit may get better once I have tried a few different coil sizes in it, as at the moment I have 2x 3mm 5 wrap spaced twisted flat wire coils in it reading at 0.156ohm.
Gonna rebuild it tonight and see how it goes with either 2.5mm or 3.5mm.
Juice wise I am using Gorilla Juice of Ebay, mainly Blackcurrant Menthol or Vimto Menthol, but I found one by another company the other day that I used which was a Rasberry Skittles and, went through 100ml in 3 days it was that nice where as this Gorilla Juice I normally go through 100ml in about 5 days.
Working at home though means I use it more, hence why I want to get in to making my own, I have just got to get another 5 liter bottle of VG fluid and then I can try some more flavour concentrates.
__________________
  #184
Old 07-06-19, 07:50 PM
Advanced Member
popped out today and got me a dual recurve since i really like the single and im not disappointed
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
