Thread Tools Display Modes
  #251
Old 11-09-13, 03:33 PM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
I'm Back, Bitches!
Aaand I'm back!
Originally Posted by The Orange One View Post
Hope you have a speedy recovery Alpenwasser
Thanks! So far things are looking good, but I'm still somewhat restricted. But I'm on
track for starting college next week as far as I can tell.
Originally Posted by Mizugetsu View Post
I just read the thread and how are you finding the 480 from alphacool since ekwb have no 480 coolstream xt's available at the moment so looking for a replacement
If you're looking for performance numbers, I recommend having a look at Martin's
Liquid Lab's review here. It's pretty much the best W/C gear review site I know of.
I haven't really put it through its paces yet, but build quality is pretty good. Other
than that there isn't too much I can say about it, it's a radiator.
One thing I don't like too much is that they use M3 threads, which can be ripped out
rather easily. I'd much prefer M4 threads (such as on the Hardware Labs radiators),
which are more solid (UNC 6-32 would also be stronger than M3, but I'm a metric
kinda guy ). But I doubt it's the only radiator with that flaw.
Bottom line: I can recommend it. Build quality is not as phenomenal as HW Labs,
but decent enough, and performance for low speed fans (as per Martin's review)
is excellent. I also have a UT60, which I've actually been using for quite a while now,
and it has held up very well.
Build Status
Since college starts next week and I'm currently somewhat busy prepping for that
(leaving aside that I'm not @ 100% yet) progress won't be quick for the foreseeable
future.
Next thing on my TODO list is still the tubing, for which I'm waiting on an order. Once
that's arrived (I hope some time next week), there should be an update towards
the end of next week if things go to plan.
So long, mateys!
  #252
Old 13-09-13, 03:50 AM
Cxizent's Avatar
Cxizent Cxizent is offline
Newbie
He's alive!
So glad to hear you're on the mend dude, just take it easy =P don't want you out of commission even longer.
Good luck with College, too.
  #253
Old 13-09-13, 12:50 PM
Gk1ngs Gk1ngs is offline
Newbie
Glad to hear your recovery is going well. It's good that you are feeling well enough for college, and good luck with it.
Take it easy still and don't push your self to hard.
Looking forward to more on this build in the future when your up to it and have the parts.
  #254
Old 13-09-13, 04:32 PM
OC3D Elite
Originally Posted by Cxizent View Post
He's alive!
Yep, still breathing...
Luckily my college schedule won't be too stuffed in the beginning since I've already
done some of the courses (or rather: I can transfer some of the credits from my earlier
degree over to this one), so while I won't be able to "take it easy" (wouldn't want
to get cocky and fall behind) I will have a reduced workload compared to those
starting from scratch.
So things are looking good at the moment. Slow but steady...
  #255
Old 14-09-13, 04:51 PM
OC3D Elite
Bitfenix Spectre Pro Copper Edition
Prototype: Bitfenix Spectre Pro Copper Edition
This is just a prototype. The fan is very annoying to take apart and before I do this
with all the rest of them I need to make sure the process doesn't damage the bearing
or anything like that. So: testing.
But, in the meantime, I thought I'd present you with this:
(click image for full res)
  #256
Old 14-09-13, 04:52 PM
maniac's Avatar
maniac maniac is offline
OC3D Elite
hoooolyyyyyyyyyy geezuss that looks good! 15/10 :P
__________________
NZXT Switch 810 - Intel i7 3770k - Gigabyte G1 GTX1070 - AsRock Z77 Extreme3 - Corsair Vengeance 2866 12GB
Corsair H110 - Corsair HX850 - Patriot Burst 1TB - Asus VX24AH - Logitech G510 - Corsair G502
  #257
Old 14-09-13, 04:59 PM
Sir-Weasel's Avatar
Sir-Weasel Sir-Weasel is offline
Member
best looking fans i have ever seen
bitfenix needs to produce these
  #258
Old 14-09-13, 05:02 PM
Jordan Jordan is offline
Advanced Member
Wow that fan is incredible!
  #259
Old 14-09-13, 05:05 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Damn... that's sexy.
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #260
Old 14-09-13, 05:58 PM
Bartacus Bartacus is offline
OC3D Elite
What they said. Damn that looks good!
__________________
Guts: ThreadRipper 2950X / GB Aorus Xtreme X399 / 64GB TridentZ Royal 3600CL16 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU
Storage: 6TB RAID0 NVME array (ADATA SX8200 Pro 2TB x 3)
Water Cooling: HeatKiller TR4-Pro CPU block / HeatKiller IV GPU blocks / 360mm Darskide LP360 rads x 3 / Heatkiller reservoir
Tags
560 radiator, caselabs smh10, copper, evga sr-2, geforce titan
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
