Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #21
Old 06-01-15, 05:42 PM
RadeonHDx RadeonHDx is offline
OC3D Elite
Have you already tried changing the fan configuration to one we have suggested? If so and you are still getting high temperatures, is there any chance that your 780 is pumping out huge amounts of heat? I honestly cant think of what might be causing this because you shouldn't be seeing temps of 50C at idle.
__________________
Intel Xeon E5649 x2 | Custom Water Loop
Saphire R9 290 Tri-X Edition | InWin Dragon Rider White
24GB Samsung RAM | SuperMicro X8DTi R2.0
Samsung Evo 250GB | 1TB Hitachi HDD
  #22
Old 06-01-15, 05:43 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
I find it really odd that all cores seem to be the exact same temperature? That's never really the case.
How is the pump hooked up on your unit? Does it go on a motherboard fan header like my H60 pump does? If yes, go into the bios and make sure that 'fan' is set to go at full speed all the time, otherwise it won't supply the pump with enough voltage to work at full speed.
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #23
Old 06-01-15, 05:45 PM
OC3D Elite
The temps on the FX series CPU's never have different temps across the cores, they are all the same, all the time so it's almost impossible to judge what core is what temperature. I think it just either takes the temperature of one core or takes them all and makes an average.
__________________
  #24
Old 06-01-15, 06:24 PM
rfm rfm is offline
Newbie
Ive got some better fans on the way this week, SP120's ill try then.
Ive got them set up in the ai suite to ramp up to 100% when it reaches 40, so basically its always on 100%
what would you say would work better? Push/Pull or push push?
Thanks for the help, means alot
  #25
Old 06-01-15, 06:30 PM
OC3D Elite
Really, you want to be running the pump at 100% at all times on an AIO because when you start to mess with the speed on the pump, it really doesn't like it.
Also, and I'm speaking from experience here, You are going to find it insanely difficult to cool your 8350 with a slim 120mm cooler. When I had my H60 on my 8320 I had to undervolt it to about 1.175v just to get it to not overheat and the idles I had were about 35C (margin of error of yours).
__________________
  #26
Old 06-01-15, 06:42 PM
rfm rfm is offline
Newbie
Ill make it run at 100% later tonight, what all in one cooler would you recommend for under 100£?
  #27
Old 06-01-15, 07:43 PM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
My 8320 (@1.35v) was happily staying at 50c with a seidon 120m (which has a slightly thicker rads).
I'd say get a H100 or h100i.
__________________
Rig: i7 [email protected]|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904| 970 EVO 500GB m.2|512GB evo 840| Crucial MX 500 500GB|ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
  #28
Old 07-01-15, 01:51 AM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Under 100£ I'm not sure, but the Corsair H100i is a good one (240mm rad, if you can fit one) or maybe a double thick 120?...
Not sure here, as you see... Feronix, barnsley and the others knows this e more than me lol
  #29
Old 07-01-15, 06:58 AM
YouWhat's Avatar
YouWhat YouWhat is offline
OC3D Crew
Originally Posted by Chrazey View Post
Say what?... Even though you had that filter, it still came dust in?... I mean, obviously it won't stop dust to 100%, but from your post it sounded worse than what I thought lol. And I've gotten that filter as well (not used it yet though as haven't started the swapping of my case yet though.
There are a few vent holes around case that aren't covered by dust filters, and with the extra 2 AF120's installed in my case, it was pulling too much air in, so through those unfiltered vent holes, it was sucking in dust.
The filters work fine, there nothing wrong with them, and now I have taken out those extra fans, the dust problem is now a non-issue as all the air into case is filtered, and the unfiltered holes are pushing air out (managed to achieved the right amount of positive pressure inside case).
__________________
Intel i7 4790K | Asus ROG Maximus VII Hero | 2 x Asus ROG Striker Platinum 4GB GTX 760 in SLI
16GB Corsair Vengeance Pro @ 2400 | Corsair RM 850 | Corsair H100i | Corsair Obsidian 750D
  #30
Old 07-01-15, 07:56 AM
Dawelio's Avatar
OC3D Elite
Well that last part just sounded like sweet music to my ears mate, lovely to ear you managed to fix the dust problem!
Tags
water cooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
