  #1
Old 28-10-15, 08:27 AM
the_bone_reaper's Avatar
the_bone_reaper the_bone_reaper is offline
Member
Bones build 2016
i am going to upgrade to a 1151 build next year. i am going to post what components i will most likely i am going to use.
CPU Intel Core i7 6700K
Motherboard Gigabyte GA-Z170X-Gaming G1 Motherboard or ASUS Maximus VIII Extreme Motherboard
RAM no clue yet
Storage Wd black 3t/ Samsung 850 EVO Series 250GB 2.5in SSD / samsum 840 pro 128 gb
cpu cooling no clue yet
case no clue
Graphic card ASUS GeForce GTX 980 Strix DirectCU II 4GB
PSU Corsair AX860i Platinum Power Supply with CableMod C-Series AXi, HXi & RM Cable Kit Black/Orange
Peripherals
mouse
ROCCAT™ Tyon Mouse
speakers
Logitech Z506 5.1 Surround Sound Speakers
headphone
astro A50 Keyboards SteelSeries Apex Illuminated Gaming Keyboard witch i will change
my budget is around $4500 max
i think this is everything so far.( note i am taking part out of my old rig witch is going to my parents) please tell me if anything is missing
  #2
Old 28-10-15, 10:42 AM
Oseth's Avatar
Oseth Oseth is offline
Member
RAM no clue yet
case no clue
Peripherals
mouse
ROCCAT™ Tyon Mouse
speakers
headphone
Why two SSDs?
__________________
  #3
Old 28-10-15, 10:50 AM
Member
Samsung 850 EVO Series 250GB 2.5in SSD os +in portent thing
samsum 840 pro 128 gb steam games
but i my stick with the Samsung 850 EVO Series 250GB 2.5in SSD for this build
  #4
Old 28-10-15, 10:52 AM
Oseth's Avatar
Member
I see, so you will just dedicate that single SSD to Steam? Will that be enough? Some games are huge, GTA is about 50gb I think, not sure what you will play.
__________________
  #5
Old 28-10-15, 10:56 AM
Member
ok you have a point and i have no idea what to say about this really
  #6
Old 28-10-15, 12:13 PM
jimma47's Avatar
jimma47 jimma47 is offline
OC3D Elite
4.5k budget you've got plenty to upsize the SSDs. 1tb at least. Still leaves room for the GPU and a decent mobo and CPU. 16gb DDR4, AIO, Upgrade to a 980 Ti Classy. Fractal Define S case and still have money left.
I just did a quick wishlist and was around 4k. (Unless you want a good monitor in the price?)
Anyways just a quick list nothing checked for ultra features or compatibility. Gives you an idea tho and if half your stuff is from your last build you'll have plenty of money left.
If the link doesn't work go to pccg and search wishlists for Bones Skylake Build
http://www.pccasegear.com/index.php?...ion=wish_lists
__________________
Rig Gallery - Krusty III
  #7
Old 28-10-15, 12:34 PM
Member
i really do not think i need to get a new graphic card since i only got it this year
do you really think a 1t ssd is something to go for
also witch mobo should i get Gigabyte GA-Z170X-Gaming G1 Motherboardor the ASUS Maximus VIII Extreme Motherboard
and the case i am torn between
Corsair Graphite 780T Black Full Tower Case or
Corsair Obsidian 750D Case with Window or
Thermaltake Core X9 E-ATX Cube Case or
Corsair Carbide Air 540 High Airflow ATX Cube Case so yer
  #8
Old 28-10-15, 12:40 PM
jimma47's Avatar
OC3D Elite
Well that saves you $1100 so a good start. I like the Air 540 personally although the 780T looks nice as well. Get whichever you like the look of best.
Both those motherboards are awesome so aesthetics will probably be your focus if your case has a nice window. Can't go wrong with either of them.
__________________
  #9
Old 29-10-15, 12:22 AM
Member
I think I'm going to go with a gigabyte board. Tower still have no idea but it maybe a white case
  #10
Old 29-10-15, 02:47 AM
Oseth's Avatar
Member
Jimma47 is right, a single big SSD would be a better choice then two smaller ones. You could always partition it in half when you set everything up and that way you have one partition for games and the other for your OS.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
