Go Back   OC3D Forums > [OC3D] Processors & Platforms > Overclocking
  #1
Old 09-09-14, 12:24 PM
Conchubair's Avatar
Conchubair Conchubair is offline
Member
My first time OCing, maybe yous can keep an eye on me..
I hope this is something that im actually allowed to post here..
So my first time overclocking, have a 4770k, H105 and a Maximus 7 Hero.
I didnt spend much time trying to see what the lowestIi could run stock was. 1.05v wouldnt boot Windows at 36 multiplier, so I went up to 1.1 and got in, and kept stable with OCCT linpack AVX. Then I put memory in at rated (1600 9 9 9 24 1.5v) which crashed when the memory loaded up in OCCT. However I rebooted and it was stable after 2 other 30min runs. i went to to 40 multiplier (still 36 on cache) which needed 1.175v to boot. this then passed OCCT AVX for 1hr, i cant remember the temps but i think i was about 70. After this passed i went to play Planetside on it, which was not stable, crashing the system twice in 48-96vs48-96 fights, not something id seen before with my rig in the sig. Maybe that was the RAM loading up suddenly and crashing, ill try it at 1333 later..
Saved profile and loaded defaults, but will give the OC another shot tonight.
i was worried about the cpu inital boot voltage though. i assume it only is at that for .1 seconds or something but 1.7 volts scared the outta me..
also OCCT reported 1.7 volts V-core. i thought V-core was the volts id set to 1.175.. so when i saw that i shat myself..
This is what im at right now..
__________________
My Rig:
i5 3470_ASUS HD 7950 DirectCU II_ASUS P8H77-V_Barracuda 500GB_Corsair Vengence 8GB 1600MHz_Antec HCG620_Corsair M65_Coolermaster Quickfire_Corsair 1300_Corsair 750D_ Samsung 120GB EVO
  #2
Old 09-09-14, 12:32 PM
tinytomlogan's Avatar
The Guvnor
CPUZ is the one to watch for vcore - programs can read things in the bios wrong.
Ive done an overclocking guide - you should look it up. Start from the beginning and get things set up right before you start to wang things. Also work on one thing at a time - basically FOLLOW MY GUIDE
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #3
Old 09-09-14, 12:41 PM
Conchubair's Avatar
Member
thats what ive been looking at, just the change in BIOS has been confusing me.. and yeah ive been trying to only do one at a time, but i think i changed stuff before it really was stable, i only thought it was..
__________________
My Rig:
  #4
Old 12-10-14, 07:23 AM
Hasilyin Hasilyin is offline
Newbie
Did you change the BCLK? If so, what did you change it to?
Concerning the 1.7v: that stuff really isn't healthy ... Did you check all your settings afterwards? Vcore, Vdroop, etc...
Also, read this article on LLC: http://forum.overclock3d.net/showthread.php?t=46502
And this guide in general: http://forum.overclock3d.net/showthread.php?t=45604
__________________
CM Storm Trooper | MSI GTX 780 TF OC x2 (2-way SLI) | i7-4820k with Scythe Katana 4 CPU Cooler @ 4.5GHz | Corsair 2x8GB DDR3 Vengeance | Asus P9x79 LE socket 2011 | Kingston SSD 2.5" 120GB HyperX 3K | Western Digital Harddisk 3.5" Green 4TB | OCZ 1250W Modular PSU
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
