01-12-11, 02:18 PM
Newbie
Hi All =]
Would just like to know peoples oppinions on quick disconnects in loops.
The only thing thats detering me is that they can be ugly, but if placed well I guess they can work!
over to you
Thanks,
Kev
01-12-11, 02:53 PM
Moderator
I try to avoid them at all costs mostly however i have been impressed with the Koolance ones, they maintain almost all of the flow and are damn near perfect at stopping spillage at most you could possibly get a half a drop if your lucky
follow the link to see the ones I have used in the past
Koolance Quick disconnect
01-12-11, 05:36 PM
OC3D Elite
Agree. Koolance seem to be the ones with the best reviews, they don't leak much at all on disconnect but I haven't tried any myself...
28-12-13, 08:27 PM
Newbie
They got even better ones now
I have 4 of them in my loop running a 4670k and a GTX 780 all with a ddc pump powering it all...
28-12-13, 08:38 PM
OC3D Elite
I think they're expensive and unnecessary to be honest. Most look pretty ugly because of how bulky they are, so if you use them I'd want to make sure you have somewhere to hide them out of sight.
Do you think you'll need to be removing any components often, because for the most part they just get left once it's finished. If you will be fiddling a lot they will be handy and save you money in coolant, but I've personally never felt any need to have them.
28-12-13, 08:49 PM
Newbie
Quick disconnects.
I do change out graphic cards quite often 3 times with this build so far (6970 to gtx670 to gtx780 to gtx780 sli if I can find a good deal). And I agree with trying to hide them but the fact that I can pull my loop completely apart and put it back together is something that is just a huge time saver for me. I'm someone without much room work with and not having coolant and hoses everywhere is a god send (other than initial install). My motherboard is also setup so when I buy in to next gen stuff all I do is swap the CPU water block and I'm set.
28-12-13, 08:53 PM
OC3D Elite
Fair enough if you get a lot of use out of them
28-12-13, 09:05 PM
OC3D Elite
After taking an old loop apart today with no disconnects in it, I don't have a problem putting six quick disconnects in the system I am building now.
28-12-13, 09:57 PM
Newbie
There not to bad when it comes to cleaning. Most of the time the coolant is still good but the radiators are clogged with dust and having the flexibility to remove them completely to clean is great. The set up I have now is just 8 to 12 screws to remove a radiator and to rinse it out on the outside. This gets the du at completely out and keep your system running like new longer.
28-12-13, 10:40 PM
Newbie
I have 2 from a rig a buy to dismantle for parts, i dont know what make they are but i decided not to use them as they seemed very restrictive, even when you blow air though them ...so somthing to look out for when buying
Thread Tools |
Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
