OC3D Forums
OC3D Forums (https://forum.overclock3d.net/index.php)
-   Suggestions (https://forum.overclock3d.net/forumdisplay.php?f=15)
-   -   PCIE Wifi Adapter suggestions? (https://forum.overclock3d.net/showthread.php?t=94236)
DwarfAdigginAhole 04-04-20 09:52 AM
Was looking at ether the TP-Link AX3000 or the Aorus GC-Wbax200. Anyone have any other suggestions or any input on these two cards?
Avet 04-04-20 03:58 PM
As near as makes no difference. I would pick Gigabyte because it wouldn't clash with other components.
Advice: Use WiFi only if you absolutely and undisputedly must. I would drill a hole through a concrete wall with a spoon so I could run a cable over using WiFi on my main system.
Davva2004 05-04-20 12:45 AM
This. Whilst I used an SDS drill instead of a spoon, I went out the lounge wall with 25 metres of exterior grade Cat 6a cable, up the wall of the house, into the eaves, across the loft, and down the wall into the gaming room. Terminated both ends with faceplates and backboxes.
And at 37 for the kit, it's significantly cheaper than a wifi adapter and if |I choose to upgrage to 10G networking later I can do.
https://www.ebay.co.uk/itm/25m-CAT6a...oAAOSwDkta~Z54
The only reason to NOT use it is if you don't own your own place and your landlord or parents won't allow you to drill through the walls.
