OC3D Mail Down?
Hyper
Hey all,
Long time no speak!!
Just thought I would quickly drop in and ask if the OC3D mail is working for anyone else,
As in @mhz.ms and the rest of them,
I ussually view my mail through Outlook but I am just getting a server error for the last few days,
Any ideas?
Thanks, Sam
I think Jim has put all the email on its own dedicated server now,
I had to change my outlook details to get it to work again.
Whats the 'number' in the first bit of you account seversettings in outlook dude? 1 or 2?
(dont wanna give the whole addy away)
There is a setting that says something like "My server required authentication (or loggin in)" Try enableing that.
1 is correct now iirc, use POP3 and "log on using clear text authentication"
Thats what mine is, other than that you need to get on the Jimbo hotline
if you boys be patient there is talk of a oc3d members email like
maxw(at)oc3dcrew.co.uk
maxw(at)oc3dmember.co.uk
ect ect, just give it some time and it will get posted on the forum if it happens
What program are you using,
Cant find that setting anywhere in Outlook 2003.
Jims retweaked the servers today, give it till the morning and all should be well again.
Teething problems on a completely new system thats all this is.
