Zm-mfc2 Or Hardcano 12
DOMINATOR
Need Help On These Two Products, I Prefere The Zalman Zm-mfc2 More But Worried About My Door Wont Close
I Have The Soprano Dx Case And The Case Door Curves And Has A Tight Fit On Right Hand Side (where The Knob Is On Zm-mfc2)
**i Was Wondering If Anyone Has Zm-mfc2 And Could Tell Me The Knob Length
**also If You Have The Hardcano 12, I Have Heard That This Caused Problems As It May Stick Out A Bit And Door May Not Close, Does It?
If You Have Any Of These 2 Products In My Case "soprano Dx" That Would Be Great As Then I Know It Will Fit.
I would personally go with the zalman. And I dont think there should be problems with fitting. Try checking case measurements that might help. Or what I tend to do is I jsut ask someone who works at the store.
