Zalman Z11 neo
Tolemac
Active member
I have just received a Z11 neo and I want to get rid of my noctua NH-D14 for a liquid cooling solution and im in need of ideas it will take a 240mm rad in need of good advice thanks in advance
All in one or custom loop? If all in one, then the H105 ticks all your boxes. It has the best cooling performance of all the 240mm AIOs.
I was looking at AIO as i've never done a custom loop basically after getting my tape measure out I have 55mm clearance for the rad in the top I measured from the top fan to the motherboard
EDIT: I have just finished putting all my components in my new case and wow is all I can say for £52 its wide enough for my Noctua NH-D14 and supports water cooling AIO's what a bargain of a case
Hmm i've been looking at the corsair H100i GTX but can't find a review yet maybe they are too new
