you guys have got yourselfs a new teammate
wotevajjjj
hi,
I just started folding yesterday.
but ive also got a question, how do i get F@H to use my hardware more ? ive got it set at 100% but my cpu and gpu are never used more than 88%
mate im still trying to fold!!
Need a bit more info.
What client (s) are you using?
What hardware are you using.
When you started did you use / set any flags?
Can you post your f@h log?
Cheers
i'm using the tracker now, looks like its getting everything out of my system, still have 0 points after 4 WU's
Hey mate first of welcome to the team
and second something is wrong you are def not getting the points for the WU's you Folded ,
Your Extreme stats link..
http://folding.extremeoverclocking.com/user_summary.php?s=&u=544867
Something is setup wrong that makes it look like you are not finishing the WU's on time or it ERRORS somewhere in between a WU,
Can you post the F@H log of the client you are using , its located where the tracker program is,
if you use the SMP go into that map and copy paste it in here if you use the CPU or GPU post those logs please !
1 more thing guys, i now had my system running that client and the normal fah for 5 hours and i havent got any point yet and it also says only 4 wu's.
and no
Checked Stanford and it shows 4 WU's and 0 points, so 4 WU's have been submitted and 0 points awarded. That indicates that the WU's were Early Unit Ends or EUE's. The WU started but ended before completion.
k thx and 1 last thing, why is cpu disable but running at 100% and smp is still at 0.0% while my gpu got to 13%
sry, i'm a noob
I wonder if it has anything to do with the 3.45 version of Tracker as I notice you have detect and install new versions of tracker. 3.45 has only just come out and may have stability issues. I am still using version 3.34 which is fine and I turn down my prompt to update everytime I start it
Let me look for the 3.34 link. look here
i'll try when this one is done
smp is at 4% now and gpu at 57 and i finally got a score
