XSPC Raystorm mod to AM4
RobM
Active member
Almost at the point I can make a start on my first loop.
Just need 6 soft tune compression fittings and coolant
I have a used Raystorm but it is AM3 and the AM4 brackets are no longer available.
I was wondering if anyone had modded a bracket to fit am4, it looks as if I might just need to elongate the holes.
Get an AM4 asetek bracket. They're about £2 and will give you a perfect template.
Here.
Bolt it down to your block using the AM3 holes and some M3 bolts and nuts, then simply drill out the extra holes for AM4.
If you can't locate one reasonably priced hit me up and I will send mine. However do note, I have a very busy two weeks coming up so it probably won't happen until after that.
