Hello experts,
New to the forum and hoping that i can get some advice here. I probably would have been able to look around a bit but I am kind of in a hurry. So as the title says I am looking at buying the RS360 kit to cool my i5 2500k which is running at 4.7GHz. Down here in Australia in the summer the other day i noticed it IDLING at 47 degrees which for me is too hot. So before I pop down to the localish store, I want to make sure I am getting everything and I wont have any problems because I get paranoid about my PC, every BSOD I nearly have a heart attack. So my local store is http://www.pccasegear.com/ and I dont really want to be going anywhere else because, I dont really know anywhere else. My list currently includes:
The kit- http://www.pccasegear.com/index.php?main_page=product_info&products_id=16616
3 fans- http://www.pccasegear.com/index.php?main_page=product_info&products_id=11128
The fans may go in a push pull with the ones with the kit or i may just use them. My questions still remain around coolant and tubing. I know I can use distilled water with maybe some red dye to match my HAF 932 Advance, but is there anything i should particularly look out for in the water or really look for. Secondly the tubing
http://www.pccasegear.com/index.php?main_page=index&cPath=207_160_853
this is what I have got to choose from because I heard that the tubing with the kit tends to kink a little so I want some tough stuff. I want a strong fit but I think 1/2" might not be enough and 3/8" might be too much, any ideas.
Lastly when i posted about this over at Avsim, I am a mad flight simmer, they mentioned something about silver kink coil or something, I am not really sure and dye clogging up the pump. What are your views on that?
Thanks so much,
Andrew
Thanks so much,
Andrew
