XSPC Antec p160
nunzio
Well this is my first real project.
Here are the specs.
AMD x2 3800+ (Stock)
MSI K8N Diamond
ATI X1900XT
4GB GeIL PC3200 DDR
XSPC Cpu block
XSPC Chipset block
XSPC VGA block
XSPC 5.1/4 Resbay
XSPC 240mm Rad (Two Xlient 120mm Red fans)
SwitchTech Radmount
Here are a few photos.
Currently I have a leaky pump, but hoping some sealant will solve this.
Looks good. You should really try and do away with those 90* bends though, even if it means changing the tubing. And maybe add some more fans to that rad ;)
Nice mate, I have the exact same case. WCing setup looks good, but yeah deffo got to get rid of the bends.
Can you stretch for a new pump mate? Unfortunately, XSPC pumps offer mediocre performance and the impeller shaft is made from a poor quality plastic. The impeller has been known to wear down over time and you could possibly see your pump start eating itself within only 4 months of use.
As far as the leaks are concerned, you must have the first version. Revision 2 (which is now available), has had changes made to the inlet and outlet to avoid leaks and the barbs have been changed.
In a few months I can. This one will have to cope until then :( When I change the case, as that one is old, and the bayres doesnt fit well on the antec slides, then I will change the pump for a better one.
Well.. just found out that some how, during the install I fscked up my northbridge.. the mobo wont post now and there is a slight discolouring of the chip :(
You can pick up an NF4 DFI pretty cheap now, just make sure you do the NB block up nice and tight this time :p
Sweet loop man! :)
Hard luck on the motherboard.. post some piccars of when you get your new board!?
BTW - I would put some gromits on the tubes where they come through the PCI slots. Can never be too careful! ;)
name='Toxcity' said:
Sweet loop man! :)
Never thought of that!
Ilwyd, I've heard that DFI boards can be right buggers to setup.
Think also that I will get a lapping kit. And not use a silver based tim. Also going to move back to my Akasa case, has more space and the res fits better.
All will have to wait until April, no time til then :(
Right I've been thinking about this.. Going to go a whole new way and replace the bits i've already got.
Hows this sound for a loop.
Res-Pump-CPU-spliter(10mm-2x6mm)-1nb 2sb-spliter(2x6mm-10mm)-120Rad-VGA1-VGA2-240mm-Res
Cooling.
Intel C2D 6300 (Dunno about OC)
Two evga 8800GTS 320MB
evga 680i Motherboard
All 10mm, besides the north/south bridges which would be 6mm.
