pcjunkie429
That's for the information man! I'll try to plan everything right before I buy the stuff![]()
No problemo dude
One more thing. As James said above, if you do go with that Phobya res and a separate pump, they are going to be 2 different types of screws/threads. I would suggest an EK Uni-Holder bracket set so that you can mount the res using the existing holes in the 5.25" drive bays. You screw the Uni-Holder brackets into the holes on the drive cage first, then using the clamp(s)/bracket(s) that come with the res, mount the res to the Uni-Holder bracket. Makes for a really clean looking, relatively simple installation.
