XFX "XT" HD 5870 flashed to Asus
Azurite
The flash was successful and i am now able to overclock 1200/1400 in the CCC. When i use MSI afterburner i am not able to adjust voltage settings. Any suggestions on why and how to fix this?
I put this bios on my last card and all I had too do was go into options in afterburner and click unlock the voltage settings, have you done that?
No il try and and figure that out. Thanks
edit. it works now
MSI says 800 mV. Does this seem right to you? they are stock now at 850/1200. Think it had over 1000mV with the xfx bios 865/1300. Heres a screenshot of it: http://bildr.no/view/847925
GpuZ says other voltage measure: http://bildr.no/view/847933
RealNeil: im doing it so i can buypass 900/1300
Edit. I solved it by pressing reset on the msi afterb. It showes 1162 mV now. Looks right now and im gonna put on the EK waterblocks and oc the shit out of these cards.
Moderator can close this topic now.
