Yep the 60's are great CPU and you can get round the cold bug to offer better performance by:
1) In Dram setting set your ram to 233 or 250mhz (increasing the memory bandwidth) - this is a DFI only setting
2) using low HTT (FSB) and setting LDT multiplier to x5 (eg: 215*16)
The performance is still better than the x2 and these tweaks make up for the apparent lack of bandwidth (made up by tweakage above)
Of course under water they (FX60) perform much better also, I can get 3ghsz from mine using stock volts which means it very good for air cooled units too
