reeper250
Which would have better sound quality?
I use SteelSeries Siberia V2 headset. ALL THE TIME!
(Fantastic headset by the way, highly recommended)
The Creative [font=arial, sans-serif]Soundblaster X-Fi Titanium or the Asus Xonar DG?[/font]
[font=arial, sans-serif]Note that the Creative card uses PCI Expess (Small slot thing)[/font]
[font=arial, sans-serif]where as the Asus uses PCI (similar to graphics card slot)[/font]
[/font]
[font=arial, sans-serif]When I upgrade to X79, depending on which sound card, it will determine which motherboard.[/font]
[font=arial, sans-serif]The EVGA X79 SLi board WILL NOT be compatable with the Xonar DG[/font]
[font=arial, sans-serif]The Gigabyte X79 UD3 will support both[/font]
[font=arial, sans-serif]The AsRock X79 Extreme4 will support both[/font]
[font=arial, sans-serif]The Intel DX79TO will support both BUT the Asus may now fit under the graphics card (GTX460 SLi)[/font]
[/font]
[font=arial, sans-serif]I can get the Titanium for $45, but I already have the Asus Xonar DG[/font]
[/font]
[/font]
