Can be done, this is just an example. Everything but a case.
That is an excellent build for 1500, very similar to the build I was putting together last month. X79 deals are very good right now. The motherboard CPU Ram combo is a bargain.The reason i asked my original question was after looking around for components for other builds i started to notice the price of some x79 bundles was so good that when it comes to the costs of some builds you might aswell just go x79 as you can see from the example below
Asus Intel Ultimate Bundle £679.99
(Includes P9X79 PRO Motherboard, Intel Core i7-3930K &16GB DDR3)
Corsair H100 CPU Cooler £78.99
2 X Noctua NF-F12 PWM £32.96
Silverstone Raven 3 £104.98
Corsair AX650 £104.98
Western Digital 1TB Caviar Black £89.98
Corsair 120GB Force Series 3 £86.98
LG Blu-ray Reader £47.98
Windows 7 Home Premium OEM 64bit £69.99
MSI GTX 670 965MHz 2GB OC £319.99
Delivery Costs £5.00
Sub Total £1621.83
With Discount of £105
Total £1516.83
It depends on a bargain for what purpose though.
We talking gaming? Cause you can build an i5 twin gpu set up for 1200 that would be better...
That is a very good point you make about the i5 twin gpu setup but can it really be done for £1200 thou?
Here's what I was thinking - it's cutthroat and to the point. There's a bit spare for a case and admittedly I tend not to include the cost of the OS but here's what I meant.
Sure there is some tinkering to be done reference the size of ssd/hdd depending on what's needed and there is no cpu cooler (but overclocking isn't actually needed). Also doesn't include a blu-ray drive but all in all you could definitely do it for £1350 with everything you said.
Not sure why the 670 cost different amounts lol - i added the same item twice...
If i'm honest i'm not sure if i could do any better than this my self so well done sir![]()
I some how payed at least double that for the x79 system I just bought and i bet no one would even be able to tell the difference between mine and the suggestions here.
