It's not exactly a work area for my PC, nor is it my desk
But i thought i would show off what 6hours of work has done for us at work
This is the second building of 3 that we have had to fit out, the first was alot more stressful than this one (163 PCs on the first stage, 53 PCs on this one)
We mount all the kit on MDF boards which slide into cupboards which saves money on cases in the long run, also makes life easier when it comes to changing dead equipment
Majority built:
In construction:
53 TFTs which should be fun to unbox:
Networking is still being terminated so we're imaging machines locally, my little work station:
My colleague doing a pose for the camera (and part of my finger :x):
An example of the boxes we sit the PCs in, cables go up the back through a 92mm hole:
44 Imaged PCs ready to go:
^ before anyone says anything, we know alot are wonky, thats my managers fault for measuring the MDF boards wrong, only way to get all 4 corners screwed was to put them on a wonk >_<
Mess
Seeing as its partially relevant my office PC and my babies (the servers):
(quite old, alot of changes to whats seen there now)
Majority built:
In construction:
Mess
