My mate is looking at getting Windows 7
The upgrade is going at about £70.
What does he actually need to be able to install Windows 7, aka clean install (format, install and go)
Is there limitations on amount of installs?
Just it mean you need to install previous version of vista every install then upgrade or as long as there is windows you can reinstall?
He wants it on a new hard drive so am I right in thinking he needed to install his copy of Vista, put the upgrade disk in, format and install again to get 7?
