Will the Noctua NH-D14 fit my case?
Vloody
I'd like to purchase the NH-D14 CPU cooler. However, I'm not entirely sure it will fit my case.
I own a rather old HEC Compucase 6A19 midi-tower case. There should enough room between the mainboard and the side panel (180mm) to fit the Noctua beast. I am not sure though, it will fit between the PSU and the rear 120mm case fan. I've included a few pictures of my current setup (with the intel stock fan). Sorry for bad quality.
http://dl.dropbox.com/u/21029539/Case/01.JPG
http://dl.dropbox.com/u/21029539/Case/02.PNG
http://dl.dropbox.com/u/21029539/Case/03.PNG
http://dl.dropbox.com/u/21029539/Case/04.PNG
So, will the NH-D14 fit my case?
What did you take the picture with?. A Calculator!, Anyways you're best messuring up and looking at the D14 size specs from their website, Then see if it'll fit you really can't tell from pictures
I'm not sure how to measure this as I don't know where exactly will the cooler start/end after I put it in place.
Also, you're a chick, what are you doing here? Didn't they tell you all computer geeks are misogynist pigs?
