Will an XSPC X20 750 be enough for me?
TheySt0leMyName
I'm planning on getting an XSPC raystorm 750 kit to start the cooling on my rig but in the future I'm thinking of adding a GPU block (XSPC Razor GTX680) and another rad, possibly a 60mm thick 280 (not sure if that's overkill) and I'm wondering if the X20 750 that comes with the kit would be up to the task with two rads and two blocks.
The case is a CM 690ii advance. My plan is to have the 240 the kit comes with in the roof with one set of fans then when I add the second thicker rad to put it in the floor with push/pull.
I had a feeling I'd need a D5 but it was worth seeing if I could go for the cheaper option.
