Will a H100 fit?
Resonance
I have a HAF 912 (Not that great of a case) but I was just wondering if a H100 would fit on the top mount? I know a dual 120mm fan would fit... but I just wanted confirmation. Thanks.
I have the storm enforcer case - which has the same internal layout as the 912. If you use the standard hole mounts for the 120 fans it will not fit, as the roof is recessed slightly. However I remember reading when I was looking into this very thing, that someone fitted the H100 but it won't sit flush in the roof - I'll try and dig out a link where I read about it.
Are the holes anywhere close to the mounting holes?
I might try to mod it.
Came across these piccies of the h100 in the Storm Enforcer:-
to clear the digi-ram, you may have to stagger the assembly or relocate it to the major case-side.
as you can see, the radiator position has moved forward 20-25m using the 200mm fan mount.
it is doable and in a better way than shown.
  1. mount fans in a pull configuration in the stock fan mounts in roof. this will realign the assembly
  2. mount radiator to fans
  3. enjoy liquid cooling
airdeano
airdeano
will the 120mm fan in the back get in the way?
I was thinking to buy a H100... now might change to NH-D14 or other mid range air cooler.
FYI, i also have a HAF 912 and the mobo is asus p8z68-v pro.
Is it most likely that my mobo digi-ram will hinder the installation of the radiator?
