Why hello thar
Awesome, will be ordering it within the next hour.
I can assure you, buggerups are assured. Im waiting for the point a try to OC my 920 and burn a nice hole through the rest of the setup :P
Will there be a/ what is most likley to bottleneck the above setup?
lool overclocking is made easy nowadays even my mum can overclock a q6600 too 4ghz, and no there will be 0 bottlenecks that system will be like the chuck norris of pc's
lol, tbh you should start too think about ocing when you have the system built and 24/7 stable, im not the best guy too ask about ocing a core i7 because ive only owned a core i7 940 for a period of 12 days lool
best way too tell is too use it as you would everyday for around a week and too look at your temperatures every so often, it helps too be paranoid :)
Just ordered it and I swear I hear a choir of angels for a split second as I did.
ETA: 23:54 hours
ETB: 23:59 hours (estimated time of breakage)
name='Shirazz' said:
Well im in the process of ordering
1000W Corsair HX Series PSU ATX
Intel Core i7 920, D0
Gigabyte GA-EX58-UD5, Intel X58,
Coolermaster HAF932 Black
2 x 1.5TB Seagate ST31500341AS Barracuda
Noctua NH-U12P SE1366
6GB (3x2GB) Corsair Dominator DDR3
2 x 1GB Asus GTX 285 55nm, 2484MHz GDDR 3
LG GH22NS40 22x DVD±R, 16xDVD±DL
i dont see no GTX 295's :p
Ok it all just arrived, what the hell do i do now? Just put the PSU in now do i put the mobo in THEN put everything on it or visversa. HELP ME OC3D.
Btw how do i deal with all the flippin* wires.
