Who makes the best fan?
Oeh, I like that cfm:dBa ratio :o
Can you hear the fans from ~1.5 meters away when they are at full speed? How much of them do you have?
i got 3, and i can hardly hear anything over my dodgy hd, but yeah they are pretty silent, and look good.
i used deltas before but wayy too noisy, but the amount of air they push is monstruss but if you want quiet/performance go for yate loon/noctua
definatly nocutua all the way but they are little pricey and there colour scheme is just awfull, meh just spray paint em'
it depends what size you are after...
if it's 140mm or larger then i would say noctua's offerings...
but, if it is 120mm fans, then akasa apache supersilent fans do exactly what they say on the tin
I haven't played with many fans in a while but still love my scythe sflex ones.
Push plenty of air @1600 rpm and run pretty much silent on 7v.
Appreciate the offer muchly but don't need them now.
I've got the high speed Panas now which are pretty class if I'm honest. Better than I thought they would be. Run really really well on low volts.
PM me the model, either i have it or i know how i can get it.
Scythe Gentle Typhoons, best case fan i have ever used. After running some tests on the models that are similar the noctua and GT are almost spot on the same. The gentle typhoon make more of a woosh noise (if you can actually call it noise) where as the noctua sound more like ambient noise cutting in the background. Seeing as both of these are really not noticable unless you sit next to your case and listen I would pick either one of these. But I just cant stomach the noctua color scheme. I dont actually find the color too bad when the fan is alone. But when I take the jet black and white interior of my case and put noctuas against it I die a little.
Both are comparable in price, the GT's have a few more srock rpm options then noctua does.
I once made the mistake of fitting out my old kandalf with Delta fans. When i first hit that power button me and my girlfriend dived behined the Sofa. we thought a harrier jump jet was landing int he living room.
Deltas are more suitable to a hovercraft than a pc so cross them off your list lol.
But latly after seing a oc3d build on youtube i went and got some Phobya fans. absolutly stunning looking, and near as damit silent. with a nice rush of cool air. very very nice fans.
