Which mobo....
you guys r good...
Hmmm that dfi board is difficult to find so plan B..
Just been checking out the Abit IC7-G Max II advance nice mobo only £95 vat included..
The 1 thing i dont like is the crappy nb fan, on my other abit mobo an7 nb fan kept stopping after 2 weeks so i took it apart put in a single drop of oil, couple a weeks later same again stopped,went to an abit forum found out abit use cheap crappy compononts for nb fan,took it apart AGAIN oil AGAIN but this time i left off fan cover
and it,s been fine since...sorry for waffling on guys.
SO if i get the Abit IC7-G Max II advance could i remove nb fan an replace it with an heatsink......Thx for all your replys guys...DD
I've heard thats a pretty darn good bard.... Enjoy :beerchug:
Thx i will,xp120 cooler wont fit the board but this one will ThermalRight XP-90C
any good,just need to find a decent fan for the cooler and my research is just about over,then i can order parts...
XP-90C = Great HS :)
Check into high speed panaflo's and low-mid speed Delta's.
high speed panaflo..is this anything like vantech tornado had one of these, first time i booted with this it sounded like the airforce was outside house..
got a model number for that high speed panaflo..thx
No no no... Panaflo's are nice and quiet and push a good amount of air. Probably the favorite fan of overclockers throughout the world :)
I can't think of any 92mm Panaflo part numbers off the top of my head, I'll have a look for you when I get off of work.
If you'd like to see what to get, go to sidewindercomputers.com and go to the fan area. They carry all of the Panaflo's :)
name='domedosser' said:
Thx FragTek i,ll do that in a moment
Np! If they carry a fan that you want give em a buzz! They ship internationally (I imagine u don't live in the US?)
