which is best for gaming on a pc - monitor or a SAMSUNG UE46ES8000 Full HD 46" LED 3D
marcus1987
im looking at buying a new monitor/tv but i need your help as i dont which is going to be better for gaming please help
12hz 3d monitor
or
SAMSUNG UE46ES8000 Full HD 46" LED 3D TV--- link below please help
http://www.pcworld.co.uk/gbuk/samsung-ue46es8000-full-hd-46-led-3d-tv-12350422-pdt.html
if u think monitor please tell me which one and same for tv if u think there is better out there thanks alot guys
considering the tv is 1300 pounds... a monitor is a better option(and faster with less ghosting) but even at the 4-6ft range it really becomes pointless as the light will get more dim the greater you are from the source(this case tv) and will be very dark.
Go for a 2560x1440/1600 monitor basically 3 screens in one:)
Ok right I would like to which is going to be best I'm not worried about the price I really want a new tv any way but I am asking will I get the same hz out of it or more or do I buy a monitor if which 120 hz 3d monitor do I get
What kind of games will you be playing?
Bf3 and cod
Crysis 3
Loads of them mate
What screen would u buy out of the ones out at the moment
A 120Hz monitor will be better for gaming than that TV. Though it has 3D capability, it does not have a true 120Hz display when you're not using it for 3D. It will also have substantially more input lag than a 120Hz monitor.
Depends on what you still want to use it for because the tv option is really only valid if you want/need the extra screen size.. which may help that you are sitting faarther away but i would suggest you get closer and be about 1-3 ft and get a bigger monitor.
Righ ok so come on then what 3d monitor should I get then !!!!!!!! Come on people tell me please what is best for gaming
What is the best what sorry ? If you mean brand there are a few, Asus, BenQ, LG. I dont know alot about monitors so i will let other members fill in for me haha
Ok well Im thinking of this monitor benq xl2411T Gaming monitor, is this going to be a good one or is there better do u think ???
Which is newer and better ok I no u will no this lol what is the best benq monitor out at the moment for fps gaming battle field and cod and a lot more
