mr_fishbulb
At the moment I've got a master (OS and applications) and a slave (Backup, swap disk and temp folders) hard drive on the primary IDE channel. And a DVD-ROM and CD-BURNER on the secondary channel.
My DVD-ROM is starting to get read errors so I thought I'd replace it with a DVD-RW since they are cheap as anything now. That means I can also get rid of the CD-BURNER.
Would I be best moving the slave hard drive onto the secondary IDE channel with the new DVD-RW, and leaving the primary IDE channel just for the master hard drive?
If so should it be hard drive in the secondary master and DVD-RW in the secondary slave?
Cheers
Cheers
