which gtx 670 grathic card should i buy
If you keep it within Nvidia's 'allowable' overclocking range, that is to say you don't go and unlock MSI Afterburner to achieve the highest clocks possible, temps are generally extremely manageable while your noise levels are quiet. Nothing wrong with a bit of gentle overclocking, just don't push it too hard if you're worried about it :)
ok so i have found a
Gigabyte NVIDIA GeForce GTX 670 (2048 MB) (GV-N670OC-2GD) Graphics Card
like what every one sayng to buy so i am going to buy it and also i would like to no is there any point getting this screen over mine will i see much of a difference
info
monitor i have is http://www.pcworld.co.uk/gbuk/aoc-e2343f-23-led-backlit-monitor-07677510-pdt.html
change to BenQ XL2420T 24" Widescreen LED LCD Monitor:confused:
I own an Asus DCUii 670 and its amazing, jamesriley owns the KFA2 model which he says is also awesome, and i've heard great things about the Gigabyte Windforce model too. So really it all depends on which one you prefer the look of i guess seeing as the prices are very similar for the 3 of them
All the coolers are quiet enough, and all of them perform well enough. It's just whichever is cheapest and you like the look of.
The gigabyte is a good choice as it allows for a 680 waterblock if you ever want to watercool. But equally the DCII has a custom PCB, which manufacturers do make waterblocks for.
The KFA2 one doesn't however - but, it is cheaper.
Still, it's up to you, and you can't go wrong with any of them
right ok so what do u think i should do as i am not going to be watercooling the gpu
im coming from xbox 360 should i be buy this card or should i buy a cheap one first or should i just buy it please help
I would buy it mate just like seumasbeathan said, you won't regret it,
al tho my GTX680 is still sitting in its box :lol:
right i have come to a stand still i am thinking of stick to a cheap card so i will ask this i want to play games in ultra as that is what i am wanting what other cards will do this and are cheaper
