Dawelio
Active member
Hey guys,
So I've thought of getting the Silverstone Raven RVZ01 instead of the Fractal Node 202.
Now, I've noticed that it's about roughly 83 mm of space around the CPU area for a cooler. And on Silverstone's own website they "recommend" their own AIO cooler for the case, the Silverstone TD03-SLIM. At only 22mm thick rad with an 15mm fan, it's only 37mm in total thickness, it does theoretically fit.
Now, I'm not sure wether to go with that one or try with the Corsair H60 V2 or maybe an Corsair H55 (as it's tubes looks a bit more flexible than the H60's) and use an Noctua NF-F12 on either one of those (since I already have 4 of them and they literally dead quiet).
If you guys say no and go air cooling, then which one would you opt for?:
Noctua NH-L9i with an Noctua NF-A9 PWM 92mm fan.
Noctua NH-L9x65 with an Noctua NF-A9 PWM 92mm fan.
Silverstone AR06
What do you guys think and what would you recommend?...
Thanks,
Chrazye
Silverstone AR06
Thanks,
Chrazye
