Hi all
I currently have A MSI Mobo Neo2 Plat , to my understanding this mobo is not great for the Mach II for two reasons, for one the cpu placement is not great meaning it is set too low and it my cause you to bend the mach II lead in order to shut the side panel and another is the mobo does not like the sub zero temps which my cause boot problems, the above faults are quiet serious so I am looking at an upgrade and was wondering what Amd64 939 mobo's you use or recommend
Vc
Vc
