Where the rest of my disk space?! Need HELP PLEASE
Thanh55
Hi Guys
After used Intel Matrix to create a 618Gb RAID 0 from 3x500Gb HDD. After install Windows I could find the rest of space in Disk Managerment. What should I do to find the rest of disk space PLEASE help me please :worship:
I think the raid will basically hide it all other than what you have set.
You needed to ideally set the whole of the disk to raid and then partition in windows etc.
Or
Create another raid for the rest of the disk i think.
I think the raid shud be set to all of the disks in question not partitions
U need to set all the capacity as a raid0 to begin with, then partition afterwards.
There are forms of raid u can make bigger I *think*, but I'm sure raid0 aint one of em. Not 100% on that, just sounds like an option I was presented with some time ago on a far distant planet.
yeh sounds about what i was trying to say
not really an expert in raid but sounds like one of those things
to echo others above ^ You will need to RAID0 it to the full 1.5TB and then partition to whatever sizes you want afterwards.
