Ok so I've had an i7 960 for about a year now, that has been running for quite some time at a stable 4ghz over clock at around 1.26 volts.
Now i've got my custom water loop in I feel i can push things a bit further, thermally speaking at least. I'm experimenting as I type to see whats the lowest volts I can get 4.2 GHz to be stable at, so far it's looking like it's 1 notch under 1.35v.
Now i know 1.35v is the max stated voltage that intel says is ok, but how much further would you guys say is safe? I may not even be able to go much further than 1.35v as at that voltage i was hitting temps in the low 80s
anyways this is worth an experiment so all input is welcome
