what would you do
gampla
i want to watercool my build with an aio but isit really worth spending say £90 on a h80i or spend a little more and get something like a 750d and a h100i?
I don't get what you're asking? you can find either type of aio for cheap these days for starters.
possibly i have found refurbed h55, h60, zalman lq310 but i can get another case and it will fit but what im asking if you had a case that someone gave you, i have an antec one the air flows not great so would i be better off getting a slightly bigger case or stick to this and put something like a zalman lq 320/h80i?
Cooler Master Seidons are like sub £50. There are plenty of options I personally avoid refurbs as you never get the full original warranty and hell at the end of the day why was it refurbed in the first place...
New or Never.
New or Never.
i take it you saw that on maplins website?
amazon sell the h80i for 65 quid.
whether you should get a new case or not really depends on if you want a new one.
what have you got in the rest of your rig?
my build is
i5 3570k 3.4ghz
msi z77a-g43
16gb corsair vengeance lp
1tb seagate barracuda
600w silverstone strider
3x cm sickleflow fans
xfx 7870 black edition
on windows 7 64 bit
ide recommend af120 fans. ive got ive got 4 of them and have no problems with at all. all running at 5v so really quiet and move a good amount of air
well i have got my sickle flow as 2 exhaust and 1 intake so two af 120 as intake should keep it cooler
well in that case ide get 2 more sickleflows because having different fans can cause turbulence and messed up air flow due to different cfm ratings etc
but if i get a h80i or zalman lq series would i have to put 2 sickleflow fans in push pull to balance it out
H80i would be a great choice for the i5 3570k at stock, the H100i is overkill unless your considering OC'ing.
My choice H80i with a pair of Corsair SP fans in push/pull.
